供应三菱A系列可编程控制器(PLC)
供应三菱A系列可编程控制器(PLC)
供应三菱A系列可编程控制器(PLC)
电话/传真:0755-86368150 QQ:409396797 MSN:fx1n@hotmail.com 深圳菱泰兴科技
128KWROM 128K 内存用于 AD51H, AD57G 1,600.00 16KHROM 16K 步 EP-ROM 内存用于 AD57(S1/S2), AD58 2,030.00 16KQROM EP-ROM MEMORY+B213 2,030.00 16KRAM 16K STEP RAM 2,180.00 16KROM 16K STEP EP-ROM 2,030.00 256KWROM 256K 内存用于 AD51H, AD57G 2,010.00 4KEROM EP-ROM MEMORY 1,350.00 4KRAM 4K STEP MEMORY (A1N, A3NMCA-0) 1,080.00 4KROM 4K STEP EP-ROM (A1N, A3NMCA-0) 810.00 64KWROM 56K BYTE MEMORY FOR AD51H, AD57G 1,210.00 8KROM 8K STEP EP-ROM 1,350.00 A0J2HCPU 8K STEPS, 480 I/O, 1.25uS/STEP 5,100.00 A11VC VOICE OUTPUT MODULE 14,160.00 A1NCPU 6KSTEPS, 256 I/O 11,330.00 A1NCPUP21 A1NCPU WITH MELSECNET II OPTICAL DATA LINK 22,250.00 A1NCPUR21 A1NCPU WITH MELSECNET II COAXIAL DATA LINK 22,250.00 A1S32B BASE UNIT: CPU, 2 I/O & POWER SUPPLY SLOTS 1,000.00 A1S33B BASE UNIT: CPU, 3 I/O & POWER SUPPLY SLOTS 1,080.00 A1S35B BASE UNIT: CPU, 5 I/O & POWER SUPPLY SLOTS 1,100.00 A1S38B BASE UNIT: CPU, 8 I/O & POWER SUPPLY SLOTS 1,660.00 A1S38HB QnAS BASE UNIT, 8 I/O, HIGH SPEED ACCESS TIME 2,510.00 A1S42X 64 PT. DYNAMIC INPUT 3,050.00 A1S52B-S1 EXTENSION UNIT : 2 I/O SLOTS 950.00 A1S55B-S1 EXTENSION UNIT : 5 I/O SLOTS 1,060.00 A1S58B-S1 EXTENSION UNIT : 8 I/O SLOTS 1,560.00 A1S61PN INPUT : AC 100 - 240VAC OUTPUT : DC 5V 8A 1,560.00 A1S62DA D/A CONVERTER : 2 CH., 4-20mA, OR -10V-+10V 4,990.00 A1S62PN INPUT : AC 100 - 220VAC OUTPUT : DC 5V 5A, DC 24V 0.8A 1,790.00 A1S62RD3N TEMPERATURE SENSOR : PT-100, 3 WIRES 5,940.00 A1S62RD4N TEMPERATURE SENSOR : PT-100, 4 WIRES 5,940.00 A1S63ADA A/D, D/A CONVERTER : 2 INPUT/1 OUTPUT, 4-20mA, OR -10V-+10V 4,690.00 A1S63P INPUT : DC 24V OUTPUT : DC 5V 8A 2,710.00 A1S64AD A/D CONVERTER : 4 CH., 4-20mA, OR -10V-+10V 4,240.00 A1S64TCRTBW-S1 3-WIRE PT-100 I/P, TRANSISTOR O/P, 4 CHANNELS 10,430.00 A1S64TCRT-S1 THERMOCOUPLE R,K,J,T,I/P,TRANSISTOR O/P, 4 CHANNEL 8,020.00 A1S64TCTTBW-S1 3-WIRE PT-100 I/P, TRANSISTOR O/P, 4 CHANNELS 10,430.00 A1S64TCTT-S1 THERMOCOUPLE R,K,J,T,I/P,TRANSISTOR O/P, 4 CHANNEL 8,020.00 A1S65B-S1 EXTENSION UNIT : 5 I/O, POWER SUPPLY SLOTS 1,170.00 A1S66ADA A/D, D/A CONVERTER : 4 INPUT/2 OUTPUT, 4-20mA, OR -10V-+10V 8,160.00 A1S68AD A/D CONVERTER : 8 CH., 0-20mA, OR -10V-+10V 6,480.00 A1S68B-S1 EXTENSION UNIT : 8 I/O, POWER SUPPLY SLOTS 1,720.00 A1S68DAI D/A CONVERTER UNIT : 8 CH., 4-20mA 8,430.00 A1S68DAV D/A CONVERTER UNIT : 8 CH., -10V-+10V 8,430.00 A1S68TD THERMOCOUPLE INPUT : 8 CH., B, R, S, E, J, K TYPE 12,110.00 A1SC01B 55 mm EXTENSION CABLE 360.00 A1SC03B 300 mm EXTENSION CABLE 420.00 A1SC05NB 450 mm CABLE CONNECTS TO AnN EXTENSION BASE & GOT 660.00 A1SC07B 0.7M BUS CONNECTION (AnS/QnAS CPU) 590.00 A1SC07NB 700 mm CABLE CONNECTS TO AnN EXTENSION BASE & GOT 780.00 A1SC12B 1.2M BUS CONNECTION (AnS/QnAS CPU ) 850.00 A1SC30B 3M BUS CONNECTION (AnS/QnAS CPU) 1,350.00 A1SC30NB 3 M CABLE CONNECTS TO AnN EXTENSION BASE & GOT 1,980.00 A1SC50B 5M BUS CONNECTION (AnS/QnAS CPU) 1,990.00 A1SC50NB 5 M CABLE CONNECTS TO AnN EXTENSION BASE & GOT 2,650.00 A1SC60B 6 M EXTENSION CABLE 2,140.00 A1SCPUC24-R2 CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256, RS232 PORT 7,730.00 A1SD51S RS232C 2 CH., RS422/484 1 CH. 9,190.00 A1SD61 HIGH SPEED COUNTER, 1 CH., 50KPPS 6,210.00 A1SD62 HIGH SPEED COUNTER, 2 CH., 100KPPS, SINK 6,380.00 A1SD62D HIGH SPEED COUNTER, 2 CH., 200KPPS, SINK 6,830.00 A1SD62E HIGH SPEED COUNTER, 2 CH., 100KPPS, SOURCE 6,380.00 A1SD70 1 AXES, VOLTAGE OUTPUT 7,820.00 A1SD71-S2 2 AXIS, PULSE TRAIN, OUTPUT, SPEED CONTROL FUNCTION 13,980.00 A1SD71-S6 2 AXIS, PULSE TRAIN OUTPUT 14,530.00 A1SD71-S7 2 AXIS, PULSE TRAIN OUTPUT, MANUAL PULSAR INPUT 13,980.00 A1SD75-C01H CONNECTION CABLE BETWEEN A1SD75 & AD75TU 880.00 A1SD75M1 SSC NET, 1ASIS 6,830.00 A1SD75M2 SSC NET, 2ASIS 10,430.00 A1SD75M3 SSC NET, 3ASIS 14,450.00 A1SD75P1-S3 1 AXES, PULSE TRAIN OUTPUT 7,270.00 A1SD75P2-S3 2 AXIS, PULSE TRAIN OUTPUT 11,000.00 A1SD75P3-S3 3 AXIS, PULSE TRAIN OUTPUT 15,420.00 A1SG60 BLANK COVER 160.00 A1SG62 DUMMY I/O MODULE, 16/32/64 SELECTABLE 1,140.00 A1SH42 DC 12/24V : 32 PT. SINK INPUT ; 32 PT. SINK TRANSISTOR OUTPUT 4,120.00 A1SHCPU CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256 4,010.00 A1SI61 16 PT. INTERRUPT MODULE 3,100.00 A1SJ51T64 MELSECNET I/O LINK MASTER, 64 REMOTE I/O CONTROL 1,940.00 A1SJ61BT11 CC-LINK MASTER STATION MODULE 2,790.00 A1SJ61QBT11 CC-LINK MASTER MODULE 2,870.00 A1SJ71AP21 MELSECNET/II, MASTER/LOCAL, FIBER OPTIC SI-200/250 11,710.00 A1SJ71AR21 MELSECNET/II, MASTER/LOCAL, COAXIAL CABLE 11,710.00 A1SJ71AT21B MELSECNET/B, MASTER/LOCAL 7,770.00 A1SJ71BR11 MELSECNET/10, COAXIAL CABLE 13,910.00 A1SJ71E71N-B2 ETHERNET INTERFACE UNIT, 10BASE2 15,460.00 A1SJ71E71N-B5T ETHERNET INTERFACE UNIT, 10BASE-T/10BASE5 15,460.00 A1SJ71LP21 MELSECNET/10, OPTICAL FIBER SI-200/250 13,910.00 A1SJ71LP21GE MELSECNET/10, OPTICAL FIBER GI-62.5/125 22,470.00 A1SJ71LR21 MELSECNET/10, 同轴电缆 13,910.00 A1SJ71PB92D PROFIBUS-DP INTERFACE MODULE 20,660.00 A1SJ71PB96F PROFIBUS-FMS INTERFACE MODULE 20,660.00 A1SJ71PT32-S3 MELSECNET/MINI-S3 MASTER, OPTICAL/TWISTED PAIR 5,100.00 A1SJ71QBR11 MELSECNET/10 , COAXIAL, COMPACT TYPE 14,740.00 A1SJ71QC24 RS232C &RS422 I/F, COMPACT TYPE 7,370.00 A1SJ71QC24N RS232C &RS422 I/F, COMPACT TYPE(NEW) 7,050.00
可以在这里发布您的产品信息的,只要不是滥发,我们是不会删除帖子的哦。
