愛特梅爾推出用於滑塊和按鍵的觸摸控制器
愛特梅爾推出用於滑塊和按鍵的觸摸控制器
Atmel Corp.'s AT42QT2160 touch controller IC combines touch key and touch slider functions in a single device. The AT42QT2160 can control up to 16 individual touch keys with a slider comprising between two and eight of the touch key channels. In addition, the chip can also control up to 11 LEDs through a PWM output function that is controlled by the host, eliminating the need for an external LED controller.
/ Q$ a& B! [5 |- U) o$ s7 m9 V( L& k, G
1 i8 a0 Q( L0 G9 p
: ~/ @) C$ n+ ~5 J/ j
Ideal for use as a multimedia HMI controller in mobile phones and consumer applications, such as personal media players, the device has a wide voltage range of 1.8VDC to 5.5VDC and low power requirements. It uses Quantum Research Group's (acquired by Atmel in March 2008) patented charge-transfer technology, which provides robust and reliable performance, high immunity to EMI through spread-spectrum modulation and filtering algorithms, calibration of the device over life and user-defined sensitivity thresholds for individual keys. An additional patented function, adjacent key suppression (AKS), intelligently suppresses signals present from nearby keys so that only intended keys register a touch.( }* @. e5 B' e) g& @% S
* i# H0 Q, d' b9 e4 l
! m( O- I, T, S7 u4 _, \% u, `5 I5 A; c4 A4 p8 b
The AT42QT2160 has three GPIOs with PWM capability and a further eight shared output ports that provide additional standard outputs for the host without adding cost or using an extra I/O expansion device with PWM capability. Host configurability is achieved via a two-wire interface (I2C compatible). To save system power, the chip provides a system Multi-Input Wake-up (MIWU) function. This can trigger a reaction from the host or other system components via the two-wire interface, or using a dedicated output pin, when pre-defined input signals levels are reached.
+ ]+ m2 i0 P, [, m4 A- o( }) _: ~: Q- I9 k; [0 S  N4 A- @
; t' i: z6 P4 v
About Atmel) A: R: e* t/ N# I- D4 O1 A' E
8 A, x5 k" F' |Atmel Corporation, founded in 1984, is a worldwide leader in the design, manufacturing and marketing of advanced semiconductors, including advanced logic, nonvolatile memory, mixed signal and RF integrated circuits.4 ~( N9 L4 E9 \% C5 q
: l' r2 j  k; u2 w( [# i
Atmel is one of the elite new companies capable of integrating dense nonvolatile memory, logic and analog functions on a single chip. Atmel chips are manufactured using the most advanced wafer processes, including BiCMOS, CMOS and Silicon Germanium (SiGe) technologies.
