2007年中小尺寸触控面板/触摸屏产业报告
【中国触摸屏网】中小尺寸触控面板是只小于10英寸的触摸屏。大尺寸触控面板通常应用在公共场合用于信息查询,而中小尺寸触摸屏则通常使用在手机、PDA、导航设备等消费电子领域。另外触摸板/触控板跟触控面板/触摸屏不是同一个产品,所有的笔记本上都有触摸板/触控板,触摸板/触控板上是不显示任何的信息的。更多关于这个报告的简介,请阅读下面的英文。
' L6 _4 g9 G/ U% z' y) ^这个报告的价格不低: PDF电子版: 1,593.00欧元。2 I: j1 |: _: p: V- f0 C3 B) o
. a2 J6 }% S+ H& q: A
Medium-Small sized Touch Panel Industry Report, 2007" j' k+ _4 M6 I6 U4 V
! X5 c: Z# t+ Y$ f) J0 s
7 z8 N. h1 J: I- P9 z- KThe medium-smallsized touch panel here refers to the cater corner distance is less than 10 inch. The large-size touch panel is usually used in the public places for the information query, while the medium-small sized touch panel is mainly used in the cell phone, PDA, navigation and other consumption electronics fields. In addition, the touch pad is different from the touch panel, and the laptops all have the touch pad, while which can not show any information.6 C, |; {4 E* ]$ {( X" K1 ?
: d$ \& r3 \+ G5 `' I0 P
The touch panel can be divided into five classifications by technique, the vector pressure sensor touch panel, resistive touch panel, capacitive touch panel, infrared touch panel and surface acoustic wave touch panel, and the vector pressure sensor touch panel has wiped out now.
6 _$ ]1 h; | A# {$ P% m- J8 V" n8 Q3 _" c+ J
The price of the infrared touch panel is low, while its frame is fragile, it is easy to produce the light interface, and distorts under the bend surface. The design of the capacitive touch panel is good, while it is difficult to solve the distortion fundamentally. The positioning of the resistive touch panel is exact, but is it easy to be scraped. The surface acoustic wave touch panel has solved all the flaws of the other touch panels, it is clear and anti-explode, so it is suitable in the various places, but the drop and dust on the panel surface can make the touch panel become blunt, or even not to work. According to the working principle and information transmission medium, the touch panel can divided into four classifications, resistive touch panel, capacitive touch panel, infrared touch panel and surface acoustic wave touch panel. Due to the flexibility of cost and large amount of the information, the consumer electronics field nearly all uses the resistive touch panel. Now, the latest IPHONE is the special capacitive touch panel, which is called Projected Capacitive Technology, PCT, and which was developed by Zytronic in 2005; in addition, it nearly includes all the advantages and, the shortcoming is the too high cost.) z7 J/ i. g$ G: @( L5 G
6 o8 _8 K/ H3 X! q; m/ {! Z& C) VThe research and development of the touch panel was started in America in the 1960s, while the technology maturity and expansion should attribute to the Japan TP field. As the continuous popularization of the application, Japan TP field developed the TP production technology fit for the batch production, and then controlled more than 80% of the TP output capability in the world gradually. The Japan TP field still insisted on not transferring the TP technology in order to control the TP production technology. Until the 1990s, South Korea and Taiwan manufacturers had made the breakthrough on the TP technology and mass production, and then they started to have their own field in the TP market, however, the output capability and technology level was still lagged far behind Japan. In mainland China, the TP manufacturing industry started late. Currently, the top ten more resistive touch panel manufacturers are mainly distributed in PRD, but the production scale is comparatively small, and the products are mainly the low-level digital TP, and with the low labor force cost to carry on the low price market competition.4 E; K" t" L% a5 p, r
/ `7 X8 L2 g& C+ t4 t3 c
Presently, the TP market in China is still in the start-up period, and the largest TP manufacturers in China are General Touch Technology Co., Ltd and Shenyang Shougang Huaxing Computer Co., Ltd, while the products of the both are the acoustic wave touch panel, which are mainly to use with CRT computer display, etc.
x% y5 e; h% b9 f: R. `2 H: f! ^/ @# S
7 p$ \: x1 t: j$ ]3 xFrom the above table, it can be seen that the scale of the current domestic resistive touch panel manufacturers is small, and the products are all in the low-level. Nanjing Wally Electronics Technology Co., Ltd is the largest resistive touch panel manufacturer in China, as well as the only manufacturer to provide the cell phone touch panel now, while its overall output capability is relatively small. Although the resistive touch panel manufacturers have formed the certain scale on the output, the output scale of the manufacturers is small and the grade is low now, in addition, no manufacturers can own ITO membrane plating capability, they all buy the key raw materials - ITO membrane and ITO conductive glass. Due to ratio of ITO membrane and ITO conductive glass in the raw material cost accounts for 40% and 25% respectively, the production cost of the domestic resistive touch panel is everlasting high, and the manufacturers can just gain the margin profit by the low price competition via the lower labor cost.
