有人搞panel测试吗?机器问题交流!我是做设备维护的。。。。
Slot#0 V2 Firmware Version is 0x0152
' g( C ]: N$ B. l) g, ~# D9 e====================================================& H3 k9 z/ d* `, X
Start Test: 09/06/2007 15:42:29
5 L& f" c- W4 [N45/N82 Release
' }( v- d3 [7 ~& j& } ]2 r# J% `( l*** Actuating Fixture Up ***4 W+ x+ P2 F- A, ^( a
Fixture is Up-ed
5 Y: B3 p7 S! `4 J9 G, @- F M$ X
; W9 ^% q: X. L8 [0 |/ ^Serial# : 1K75M0005Y781TG0
& E C* o% s m; g3 kConfig Code: 1K1TG0# I0 H( l- g3 j$ K
DUT Powered Off - DUT voltage read 0.000V
! f; b5 O% g7 gDUT Power: 0.196 Watts ( 3.023V * 64.990mA)
9 `: ]! T- _& R. c) X V( \$ ]( x4 jBoost 18.5V is Off (0.601) - Boost_Enable_L is low
6 O& N# l# L6 f$ S& W- ^9 \Code Downloaded Successfully to V2 memory (expChkSum: 0x7A22, obtChkSum:0x7A22)
9 k9 i8 |. s5 h! v& RDownload to LPC successful.
3 u) g; r6 w5 ^) S/ B[DBG] 18.5V Power Rail reads 17.90V% @( X( Z* k- U
MTDevice properties re-cached & re-started successfully...( d! q5 D' N. ~" U7 D
Device FW Information: vers 0x0064* P; P% X) b7 I
*** Performing Power Test - UILocked ***! O( m4 E" W" T Z v! d' g @- t
Setting Powerstate to UILocked power mode3 _! X' x, O: v- C4 X
3.0V Current read : 58.603uA
, ~4 K* b! y/ V2 ^18.5V Current read : 0.000uA
# A) Q- x, `! Z0 \, _" k% ~" V" c9 W& B& W4 q
*** Performing Open Test ***( N0 k; e# Q+ M& L1 B3 u; x# E' a
Image column: 10/ \8 S4 \* X7 W
Image row: 16
, U2 q5 ^% E( [" ^" UPhantom row data:- t, F* E' i$ W7 I
0x7F90 0x8004 0x7E09 0x8091 0x7F42 0x805E 0x7F9A 0x7E36 0x7E59 0x8049
3 N$ G; C3 q$ N( G) l+ p( RColumn Threshold Hi:
_/ w# V8 v% a# E0x7F10 0x7F84 0x7D89 0x8011 0x7EC2 0x7FDE 0x7F1A 0x7DB6 0x7DD9 0x7FC9
- d- X) T) `; f) jColumn Threshold Low:
- F0 t$ s! B' ?: x! @2 G0x7890 0x7904 0x7709 0x7991 0x7842 0x795E 0x789A 0x7736 0x7759 0x7949
4 P7 j# w4 [5 z/ z/ f& J# E) U/ _; m" y1 A! V/ u9 U
row 00 (0x): 7B95 7C10 7B27 7D16 7C87 7D68 7CBF 7BF4 7C1B 7DAC , k" ~0 S, m, k! G5 a* c
row 01 (0x): 7BF8 7BF1 7AB8 7C69 7BC0 7CB9 7C25 7B60 7B8B 7D3C
% \) E P2 H4 N6 M) E9 _9 H* Qrow 02 (0x): 7C07 7BEC 7AC2 7C73 7BA8 7C73 7BE1 7B2E 7B71 7D2D
1 o' `/ I( l: lrow 03 (0x): 7C5D 7C1B 7AD8 7CA7 7BF8 7CC9 7C1B 7B4E 7B6E 7D05
! h; P& i6 `# c- Nrow 04 (0x): 7C89 7C48 7AF2 7CB8 7C07 7CD8 7C28 7B5B 7B7B 7D0D . ]8 {7 C) D; r* C+ |
row 05 (0x): 7C90 7C4E 7AEE 7CB8 7C0A 7CDB 7C29 7B5C 7B7B 7D07
1 a! |+ r r8 g+ L: w7 w, r. q( j" o- zrow 06 (0x): 7C8C 7C4C 7ADC 7CB2 7C0C 7CDB 7C2C 7B5A 7B78 7CFD - Y K" d4 ~, k
row 07 (0x): 7C69 7C23 7AA0 7C96 7BFC 7CD0 7C20 7B4B 7B5F 7CBE
& f) J1 b/ B6 K! l+ ?: brow 08 (0x): 7CF5 7CC0 7B56 7CF9 7C26 7CDA 7C10 7AF3 7A74 7B5B
% k% {% t/ R) x+ lrow 09 (0x): 7CF9 7CC2 7B59 7CFD 7C24 7CD6 7C02 7AD9 7A88 7C13 ` ~+ D7 H% v% }' P) ?( @
row 10 (0x): 7CFC 7CC5 7B5B 7CFE 7C1D 7CCA 7BE6 7AB0 7A98 7C5E
% J& l) }- l# j' ?% q& J/ frow 11 (0x): 7CFD 7CC7 7B5A 7CFE 7C15 7CBA 7BCE 7AAF 7AC9 7C85 * T' o ^- Z4 `' M g3 X
row 12 (0x): 7CFC 7CC6 7B5B 7CF8 7C0A 7CA8 7BB3 7AB5 7AE1 7C84
- l, l0 Q- p; d% U* W/ M) Lrow 13 (0x): 7CF9 7CC2 7B52 7CF2 7C09 7C95 7BAB 7ACA 7B00 7CB4
! l1 T# [( R5 \+ O" B8 ]" m9 Wrow 14 (0x): 7D56 7D1F 7B7E 7D1D 7C28 7C72 7B90 7AC1 7B35 7CE7 " J$ t2 I, U# @- [: ?) k
Open Test Passed - maxValue = 7DAC, minValue = 7A74
4 R" Z, Z0 Z; t& D
$ r6 u7 ^. H+ b7 ]/ [*** Setup Calibration Frequencies ***
0 Y# c" R! u L9 c* Q9 Y*** Retrieving Phantom row data with LGMID settings ***
+ \# s! C" D* W3 y*** Performing Phase Calibration ***' `# J' p; Y" j8 k5 w( ^/ `
. b5 B. e9 ]2 Y9 W5 A
Calibrating Phase Delay...
) j# n! N8 a. V2 D# b3 |, v( T3 \, V
6 G6 I3 _4 w# e1 c+ vrow 00: 0.061 0.049 0.048 0.053 0.057 0.054 0.056 0.056 0.063 0.068
0 H8 j! D- S% V Y0 Q R% A" r7 r
" D* Z+ ~$ X" n5 t4 T z' zrow 01: 0.060 0.050 0.050 0.056 0.058 0.053 0.055 0.055 0.062 0.067
; l6 X9 x1 V" R# Z* ~
/ p1 L1 U- z u4 Trow 02: 0.059 0.049 0.049 0.054 0.056 0.051 0.053 0.052 0.059 0.064 * h ]$ o" Q& r2 n$ s$ X
. ^( I5 ^1 z# z& v' X6 X: |row 03: 0.057 0.047 0.047 0.052 0.054 0.049 0.051 0.049 0.056 0.059 & C! H( l f, B0 }
& N& W {" \! ]( {) g6 irow 04: 0.055 0.044 0.045 0.050 0.052 0.048 0.049 0.047 0.054 0.057 - X7 i n8 J8 {
) |* X6 q4 v. l3 k% {
row 05: 0.052 0.042 0.043 0.047 0.049 0.045 0.046 0.045 0.052 0.054 + T; B9 A; \7 R2 @! ]
- A y, s8 H: p, K2 o/ ?row 06: 0.050 0.039 0.040 0.044 0.046 0.042 0.043 0.042 0.048 0.051
* c2 M3 y) v9 |* t
4 Y1 |( u( G, H0 D" @row 07: 0.046 0.035 0.037 0.041 0.043 0.038 0.040 0.039 0.046 0.049 ; e5 ^$ M( [3 Q
! j N) o3 i' N; u3 @! F" X A) c: h% ?row 08: 0.053 0.039 0.038 0.042 0.044 0.038 0.038 0.036 0.046 0.047
. Z- e3 Z8 h2 @- Z5 [# Q8 V8 [' ^! s9 U% p" U# G9 v) W, Q
row 09: 0.046 0.034 0.033 0.037 0.039 0.034 0.035 0.033 0.043 0.041 9 c8 Y, s/ e. K p
- B) v# x( J0 ?- O
row 10: 0.042 0.030 0.029 0.033 0.036 0.030 0.032 0.031 0.039 0.036
& ^, w" a4 I: X; ]; G+ I3 k3 _( N( y& p t- ^- v% w0 s
row 11: 0.038 0.025 0.025 0.029 0.031 0.027 0.029 0.027 0.033 0.032
5 s3 Q7 h+ S% m9 M* n
8 u# Z) m$ [! Rrow 12: 0.034 0.021 0.021 0.025 0.028 0.023 0.025 0.024 0.029 0.027
- J! L) O) R& ]% ^$ Q- n! c, U7 N& F0 y
row 13: 0.029 0.016 0.017 0.020 0.023 0.019 0.021 0.019 0.023 0.021
( S9 \0 ]5 u& W: }2 f* K3 \) W9 l/ H6 o: q8 G
row 14: 0.023 0.010 0.013 0.016 0.019 0.018 0.019 0.015 0.017 0.014
( U) T6 @$ f z; |4 R' U3 I( E' H& ~3 Q* `9 p+ k
Calibrated DCL:" ]2 {2 n# I. \3 R1 f- l9 f
) T3 h4 ^* b- C2 @7 O
- Low Freq (115.000KHz):
; V2 P; g0 c0 a0 }; B& S0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 5 R. F3 j! f6 x* P
6 L7 {; |" R: _9 q8 C
- Mid Freq (115.000KHz): 0 v, l. _1 {9 x6 c* |. I) e
0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 2 j, J% P% P$ ^$ A, {& g
( u8 E8 H, Z+ C( A: L. {- High Freq (300.000kHz):
9 i* }+ _7 }; F9 o! j1 1 1 1 0 0 0 0 0 0 0 0 0 0 0
* e# d. H; F! J4 VDCL_CAL_MAX Measured: 01
: Q6 L8 ? [2 bDCL_CAL_MIN Measured : 00
$ G4 R0 @9 Y: o; u4 L, DTDEL_MAX Measured: 0.068us* Q; r( h7 V; h6 y) z0 L
RES_TDEL_MAX Measured: 0.058us
' p% B- B+ i9 E" L, R; A4 B2 [Phase Delay Passed
1 f3 B2 a; v( X5 P8 u' T) ~# N, s# ]3 G
*** Retrieving Phantom row data with ADCMID settings ***
7 z. a6 s# d7 v5 Q3 c$ W( @) e
# I% X8 t( y! A! H- G3 H*** Gross Calibration of CFB ***, e9 s2 W5 V5 b6 @0 m: w
*** Performing Fine CFB Calibration ***
8 C. L C3 z: [( j; U2 Y+ A: x; B*** Actuating Fixture Down ***# [6 U& H' }8 @( Y5 q
Fixture is Down-ed
5 c( O+ d4 }- ]3 r! }1 ]6 P$ T. s7 t4 w! X9 v: Z- p% l
*** Performing Contrast Row Test ***- `* H l% H9 j. S# E. p' i
Contrast Column Test Passed - Delta maxValue = 78, minValue = 37' j& G, S. C* G# l4 Y \ t
6 O& g. M; ~5 ~8 @$ u9 x
*** Performing Contrast Column Test ***9 W* V% D- I, [
Contrast Column Test Passed - Delta maxValue = 117, minValue = 88$ j8 d+ V0 ? E! Y( H" i
, A# R: I6 F! Y( n, K1 @- a
3 v# {+ l( ^% c2 TFixture is Up-ed- j3 ~2 V3 n& t, e. B0 R. f! `3 z
x% J$ Q& u6 N; `* h% X
y9 v; l0 N- Z" N0 V3 \*** Calibration Results ***
; [. P* s7 _- EFS_INT_CAL : 4151 G6 T$ P2 u2 `" Y2 K
FS_LE_CAL : 326
+ x0 D3 w6 W" K( Y' L* f: JFS_RE_CAL : 3452 ?6 H1 [% s3 o; Z5 @/ g7 o
FS_UE_CAL : 398
5 D( k! \2 Z5 B* Y8 z: s+ TFS_BE_CAL : 372" \. ]: ~5 v6 t
FS_ULC_CAL : 2889 [6 I: ]& f9 c% c( u. Z' n
FS_URC_CAL : 326
( j, M8 }5 C9 R7 J) NFS_BLC_CAL : 317
+ ?% [, G5 G) u( |FS_BRC_CAL : 294
T( N9 ~3 e" N0 V& sRES_OFF_MAX : 029
( M# z- w* N6 h' z5 _% j: G: qRES_OFF_MIN : -640
! m3 ]8 c# p* I K3 b6 wFS_ERR_PCT_MAX : 5.797
4 q1 ]+ @6 @( K) I# EFS_ERR_PCT_MIN : -6.784
0 H9 H F! s* W2 t6 l- A/ MFS_ERR_PCT_SPAN : 12.581
% f9 `0 i6 [) A+ C/ s2 _BASE_NZRMS_MAX : 3.544
9 ]% H3 G0 z4 T; X8 ~$ aBASE_NZRMS_STDV : 0.6178 {; I; B+ K# [1 ]. J* Z
BASE_NZRMS_AVG : 1.626* \* q a! c2 [0 h6 x: _
ALL TEST PASSED* Y) S" j4 ]1 Q# |- z0 }8 O, N$ V
Total Test Time : 27.967
4 E8 M) c# ^, b% ^5 W
( S# o( Z% r9 R* D[ 本帖最后由 reloop 于 2008-5-15 14:22 编辑 ]
