紧凑型PC是非常棒的,因为这种PC不但使事情变的简单了,而且他们还能节约你的不少空间。然而,GPNC却生产了一种比你的台式机占用更多空间的PC。
这个70英寸的庞然大物需要占用比普通的台式机更多的空间,但是我敢保证许多人将不会在乎它占用的额外空间。它采用三星的液晶显示器,完全支持高清HD标准,8000:1的对比度,8ms的响应时间,700 流明的亮度。
遗憾的是,因为GPNC还没有提供其他任何的说明文档给我们,我们不能肯定这款PC的实际表现如何。我们只知道这个PC内置无线触摸屏。采用Windows XP操作系统。
GPNC shows off 70-inch touchscreen" onclick="tagshow(event)" class="t_tag">touchscreen PC
All-in-one PCs are great because they keep things simple, and generally save you a lot of space. However, GPNC has created such a PC that will take up more room than your average desktop.
This 70-inch behemoth may take up a lot more room than a regular desktop, but I can guarantee that many people wouldn’t mind the extra space it takes up. The screen is a Samsung LCD with full HD support, 8000:1 contrast ratio, 8ms response time and 700 cd/m2 brightness. I wouldn’t mind seeing how one of these did in the gaming arena.
Unfortunately, at this point we’re not sure just how well it will perform as they have not let any of the other specs be known to us. We do know that it will feature a full touchscreen as well as built-in wireless. It also appears to be loaded with Windows XP, though it doesn’t appear to be playing very well with it.
[此贴子已经被作者于2007-07-11 09:57:23编辑过]
